Reaver Asymmetry:
The asymmetry of this model is mind boggling, I suppose it's all right for the compounded curves of the Mars pattern but the Lucius requires square and true edges and panels for its faceted armour. The hull varies 1.0 to 2.0 MM between sides.
The inner surface of the carapace will have to be trued before the outer surface is applied.
Again where there are gaps between the hull carapace and the shoulder armour on the Mars the Lucius will have continuity in that the hull and shoulders will be joined and most probably a single unit. Not a problem but an interesting exercise.
Fortunately the shoulder mounts display very little Mars filigree so I should be able to get away with out replicating them in styrene. As with the Warhound the basic shoulder and legs are the same on both the Mars and Lucius.
http://i.imgur.com/U7tTbOf.jpg
It may be worthy of note the liberal use of rubber bands to hold the components together during this construction and fitting stage. Apart from the styrene work nothing is glued and all the parts are fitted to a fraction of an millimeter gap/clearance tolerance. It is worth the small added effort and time to achieve a professional looking assembly. The big failing I find with assembled (derelict) Baneblades I purchase on Ebay are the huge gaps between components usually filled with putty or glue.
