Geil
Blackadder's Lucius Pattern Reaver Conversion Kit
Greetings again!
Nice Missile Launcher, I assume you are going to add another one at the left shoulder, but what about the part above the head? Do you want to add a third one on top of it, or should these two represent the whole launcher? I don't think it would look bad, just a question how you want to use the top of your Titan as I find that part most interesting because there is the most space you can use to add additiona weapons or other tools.
Arantor
Greetings again!
Nice Missile Launcher, I assume you are going to add another one at the left shoulder, but what about the part above the head? Do you want to add a third one on top of it, or should these two represent the whole launcher? I don't think it would look bad, just a question how you want to use the top of your Titan as I find that part most interesting because there is the most space you can use to add additional weapons or other tools.
Arantor
Good question,
The two shoulder mounted rocket batteries will comprise the entire APOC missile system.
Since I already stated I am not going to use the FW APOC Rocket pod in either the Mars or the Lucius pattern version; what am I going to put on the top of the carapace instead?
The easy answer is 'Nothing'. What I want for the top of the Lucius Reaver is a clean angular superstructure showing no weapons (when the rocket batteries are stowed. My job will be to design an interesting and aesthetically pleasing carapace upper surface.
Fitting Out In Triplicate:
Quite possibly the last update this weekend but hopefully I'll have the rocket turrets finished this weekend.
The image below shows the three remaining batteries in various stages of completion:
http://i.imgur.com/klYkhqI.jpg
and I hope when they are skinned out they will look something like the Rocket pod on the FW Rocket Tank someone so graciously provided and that I was unaware of (Honestly) as seen below
Reaver Shoulder Carapace:
Coincidentally I am working on the Reaver shoulders as I prepare for shoulder surgery this coming Friday. My big concern is to not make the appendages too much like the Warhound shoulders but still maintain a Lucius appeal.
http://i.imgur.com/lCesYTR.jpg
I cut down the battery of the APOC rocket array to six tubes wide and will attempt to add instead four lower and four upper tubes to the array which I think will be more business like.
http://i.imgur.com/uUehAsb.jpg
The whole assemblies will be sheathed in armour as with the Praetor Armoured Assault Launcher.
PRAETOR -
How NOT to Design a Reaver:
This is starting to be fun. Since I started this project all I had was a vague idea of how I wanted it to look. So far I haven't made too many mistakes and had to rebuild virtually nothing. Now we are getting down to the nitty-gritty and fleshing out the carapace.
http://i.imgur.com/1tH5qek.jpg
Right now I am exploring the fascia panel angle.
http://i.imgur.com/WM6AI9z.jpg
I know that I am posting a lot of small steps but this is how I work and by plugging away bit by bit eventually before you realize it you have a Titan..........
The thing that bugs me is that now I am on a roll and in two days I'll have my right arm in a sling............ostensibly immovable for up to six weeks.
Modular Armour:
I am trying a new method of building on this project because the armour must be interchangeable with the Mars armour. All the pieces must interlock virtually seamlessly but still must be removable so as I work I continually disassemble the module components to maintain that flexibility.
http://i.imgur.com/UN1jr22.jpg
The angles on the carapace skirt are more important than the size of the pieces of styrene used so I am continually adding over-sized pieces that will be trimmed later after the structure has sufficient structural integrity.
http://i.imgur.com/sNG9LYV.jpg
I have to add about 0.5 KG/1.0 LBs to each of the void generator housings; into the box framed recesses so that area cannot be skinned as yet but I do need the angles so the rear skirt intersects properly with the housings.
A Last Flurry of Building:
It seems I'm in a panic to complete all my projects in the past few days as ridiculous as that sounds but closer I get to the deadline the faster I am working.
Now that the glue is dried the hull carapace components are readily removable. All the resin pieces are held in place by the styrene frame and everything fits nice and close. I have to duplicate all this on the other Reaver hull but that will take place next week I hope.
Here is the complete hull armour removed. It is held in place on the resin hull with a single styrene spring tab. By triggering the tab the armour comes off in one piece.
http://i.imgur.com/hdxAKTE.jpg
At the very top center of the image below you can see the tab; the rectangular opening above the tab fits around the resin vent frame above the neck. This tab will be hidden from view when the head is attached and accessible when the head is removed.
This underside view shows the front and back armour sections interlocked together:
http://i.imgur.com/6LPos1h.jpg
This last image shows the front and rear armour separated. Although the armour is just single sheets of styrene at the moment the shape is maintained even without the resin substructure. This will give me a solid base to add the internal armour skin. The armour when finished will be about 5 millimeters thick but hollow between the internal and external sheets.
Well Good news, my arm is out of the sling and and my PT says I am regaining the use of my arm better than can be expected. I actually started assembling a Hive Tyrant today and was able to cut n' file the metal pieces for a close fit so perhaps in a week or so I can start cutting Plasticard. It won't be for another 2 to 3 weeks that I'll be able to drive. This was the worst time ever to buy a '14 Challenger
It's been sitting in the garage since the day I bought it. I had 10 miles on it the day of the operation.
It sits in pristine newness awaiting me in my garage. HA!
(I had to add that last bit because someone on another forum took it that I destroyed the car (And my arm) after driving only ten miles....)
I can feel with you!
My husbands gift for me on our 10th wedding day was a weekend with a Lotus Elise. But "thanks to a frozen shoulder I'm unable to use a cltuch properly. And steering a car with servo steering still hurts enough, so its no use trying to drive a real sports-car with no driving assistance systems at all.Congrats to a beautiful car! I really like all the retro mopar cars.
Oooh a Lady, and she drives stick! mind yerself Blackadder she's married......
I hope your arm is fully recovered and you are enjoying your Lotus Elise. (I could buy two Challengers for what that Elise costs; grumble, grumble, grumble,)
Reaver Rocket Pod 2.0
He's back, finally after a seemingly interminable hiatus I have finally got enough movement back in my shoulder to actually cut plastic again......(Jeez Blackadder what a wuss!) The biggest problem was the immobilizing sling that kept my upper arm clamped across my chest. that came off last week and it took me a week just to get my motor skills back. Enough about me..........
One of the things I thought about doing was a total revamp of the Reaver Apoc Rocket pods I can't believe I was satisfied with such a tawdry effort. Some of the work may be salvageable but the "Magic Flute" look must go. Below is imaged the beginning of new rocket array middle row which I will use to build on for a more militaristic retractable pod assembly.
http://i.imgur.com/RVxExcY.jpg
Ah, I love the smell of toluene and oil of mustard in the morning.................
E. Blackadder
I contacted DISCARD the Department of Idiotic Silly Cutesy Acronyms and Redundancy Department for a suitable DOD long winded acronym for my rotating rocket pod and this is what they came up with..............the:
Self-Loading, Automated, Computerized, Kinematic, Ballistic, Line of sight, Auto-Detect & Direct, Elevating & Rotating Missile Platform.It is now known officially as the:
SLACKBLADDER MP
This? This is what has you up at 3 in the morning Blackadder? You have really got to get a life!
Apoc (Slackbladder) Missile System:
There are a few questions where I am going with this? Simply put the concept was established but I had yet to worked out the details.
Almost from the beginning I disliked the "Pan's Pipes" whimpiness of the flat array but laziness amoungst other considerations lulled me into complacency hence the self-deprecating "Slackbladder" admonition.
Last week saw me shake loose my torpor and I embarked on a more military looking rocket launch system.
http://i.imgur.com/rHUBuNp.jpg
I also had it in mind that the Reaver concept that I had (in my mind) looked too much like just an over-sized Warhound; I had to change that similarity.
http://i.imgur.com/HwnQeeb.jpg
So here we have the beginning of a more compact, more powerful looking rocket pod system.
Apoc Rocket Pod Redux:
For those who complain I take too many images of the same thing heres more of the same.
That's what I'm talk'n 'bout; this is more what I had in mind when I first conceived of mounting the rocket array in the shoulders. A compact lethal self-loading system.....I still have to work out the self loading and rethink the elevation cylinders.
Anyway below are the makings of four arrays with the possibility of two more mounted on the centerline carapace for a total of three on each Reaver provided there is space for the center array to fit.
When finished the Reaver will have a broad shoulder look with Trapezoidal ridges where the pods and the reloading system are situated.
No, I'm not actually going to make the reloading system but I will insure there is adequate space were one to be installed.
http://i.imgur.com/en4CrDL.jpg
You tend to lose sight of the scale of this thing as when I was cutting the chambers for the rockets they seem rather small but thinking about the size I realized these rockets are close to a meter in circumference.
http://i.imgur.com/jTJkSuA.jpg
That's a fair sized rocket.
Apoc Missile Array 2.0:
Final images for today show the carapace pods in their approximate stowed and firing positions.
Granted at the moment they appear too high but relative to the Mars carapace and shoulder armour they are slightly lower that the Mars equipment.
Significant progress has been made today since I have also worked out the extending and stowing cylinders.
http://i.imgur.com/Mz0XzAk.jpg
The front view shows the height above the left shoulder in the stowed position bearing in mind that all the hood and carapace components visible in this image are the underside skin not the top surface.
http://i.imgur.com/RCKD5uM.jpg
My big concern at the moment is will the extending actuators lift the array high enough to clear the carapace during line of sight missile deployment.
Martini time!
Apoc Rocket Pods Two or Three?
Its the weekend again,
Tempus fugit
Before I realized it I had crafted an update not realizing that everyone will be away or otherwise occupied in short too busy to respond to my plebeian thread. But forge ahead I must now the the die is cast.I have succeeded in making the four bare bones rocket pods and situated them on the carapace for review and I think that three may be necessary after all. just for the sake of maximizing fire power and aesthetic appeal
http://i.imgur.com/nCfnjKT.jpg
Anyone around during the weekly hiatus may want to weigh in on the path to go?
http://i.imgur.com/iZchJgA.jpgThis last post shows the left pod in the stowed position which appeals to my sense of balance. the center pod will not be retractable but will rotate as do the wing pods. an ominous triple threat to be sure.
Greetings!
Very cool rocket launchers! They are a lot better than the ones form FW, yours just look more like real weapons and as I imagine apocalyptic barrage weapons. I would also say that three launchers are better than two, not only because of the firepower but especially because of the, you already mentioned it, aesthetic appeal - it just looks better with three of these launchers.
Arantor
Not to mention almost doubling the original FW APOC rocket firepower...........Thanks,
Here we see the evolution of this rocket firing system From the original FW design to the latest version granted my concept art(?) leaves much to be desired but I don't want to waste a lot of time on preproduction drawings as I tend to get too involved with the imagined finished product picture to the exclusion of the actual building; witness my preconstruction drawings of my Jaeger Titan Hunter which took weeks to produce.
http://i.imgur.com/l0jFIkx.jpg
No, better to do quick sketches and better put the time to cutting plastic.
http://i.imgur.com/LJx5cTw.jpg
Anyway here are the drawings as it stands at the moment:
With the first picture being the original epic Reaver titan and my original rocket array thoughts on the array showing a non rotating forward firing fixed battery on either side of the main carapace but still having the capability of ballistic launching.
http://i.imgur.com/TmZkLQr.jpg
The most recent incarnation is the center battery being capable of forward firing the top two rows of rockets (9) fixed forward-line of sight in the stowed condition but also being able to firing all three rows of missiles in a ballistic trajectory.
http://i.imgur.com/vFXxign.jpg
The two wing rocket pods stowed until the situation warrants their deployment whereupon they elevate, have the capability to rotate 360° as required, and fire in a ballistic trajectory; in all a grand total 39 missiles 8 of which can also be fired line of sight. Whew!
A Tale of Six Apoc Pods:
No much to show for the weekends work but there a six basic Apoc launchers now
http://i.imgur.com/GiLyXdt.jpg
and all six have the lower angled skirt armour installed.
http://i.imgur.com/T7ALi4D.jpg
For what its worth I did watch Pacific Rim this weekend, there's a couple of hours I won't get back.....................
Apoc Pod Prototype:
Now that the basic missile array is complete its time to add the armour and detail.
I chose 2,0 MM for the thickness of the plating but used 1,0 MM styrene for the sides as 1,0 MM easier to work with. I used 2,0 MM styrene for the top plate as all that need be done is dressing the edges at about 60°. As usual there is a lot more detail on even such a simple construct than that which meets the casual glance. This is the true beauty of any FW model and the lack of which leaves the average scratch build bland in comparison regardless how many skulls and aquilae be it festooned.
In the image below I try to capture that detail and still have the ability to have the pod rotate when finished. The recess on the underside (left) will house the elevating and rotating mechanism.
The component at the right show the layered 1,0 MM side armour which the 2,0 MM top panel in the background.
http://i.imgur.com/65blUsJ.jpg
This image below shows the front end view of the pod which may need added thickness to the armour; I haven't decided as yet.
The small gray nurdle seated on the yet to be attached top panel is one of the original FW rocket nose cones supplied with the Mars APOC rocket pod to demonstrate that my Lucius rocket arrays are sufficiently robust to launch comparable sized missiles.
http://i.imgur.com/CDNXqBq.jpg
The top panel in place and I'm thinking another half millimeter of styrene thickness is in order.
http://i.imgur.com/9d0iVMU.jpg
Finally the side view showing the over extended front overhang that will be beveled about 43° undercut above the rocket nose cones and the greatly over extended rear of the pod because I haven't yet decided how long the pod needs to be................
http://i.imgur.com/eyZeVc5.jpgin relation to the yet to be detailed carapace.
A reference shot of the FW rocket array:
To show where I am heading.
