The design of the disc tilting cylinders which will mimic the movement of the human ankle. These will allow the disc to tilt side to side while secured to a longitudinal pivot axle yet to be fabricated.
In the next set of images it will become more apparent that I have chosen to use two axises of rotation as opposed to the ball and socket axis in the ankle of the FW Warhound. I opted for this design because there is much more space available for the mechanism and it is much stronger than the ball and socket joint in the Warhound. Considering this vehicle is an order of magnitude heavier than a Warhound, a more robust ankle is required.
